Latest post 09-21-2009 4:20 AM by danezro. 2 replies.
Page 1 of 1 (3 items)
  • 09-20-2009 3:21 PM
    DIY fix for an Earset 3?
    Is it just me but I have had my Earset 3 for my Serenata replaced twice already because the left ear piece just stops working.
    Before I go back to my dealer for the third time has anyone had the same problem and more importantly worked out how to fix it?  The symptom is quite simple; suddenly there is no sound from the left speaker!! There is no visible damage; all the leads etc all look absolutely fine.
    Filed under:
  • 09-20-2009 4:06 PM In reply to
    Re: DIY fix for an Earset 3?
    It will be a broken wire - maybe a solder joint in the jack plug - they will replace it - again!
  • 09-21-2009 4:20 AM In reply to
    Sounds like a common problem - thanks for the reply
