        1st March February 2012
								        12-20-2009 4:20 PM
									        Søren Hammer
								                - Joined on 01-07-2008
								                - Esbjerg/Denmark
								                - Posts 554
										    Hello Beoworlders,
I have just bought a "New" Beogram 4004 turntable, Which has been unused for a decade. This resulted that the arm permanently is in "down" position. After taking the turntable apart, I saw that all grease has seized up. After applying some WD-40 to the hydraulic cylinder and solenoid, everything began to move fine, but the solenoid cannot move fast enough to raise the arm properly.
My father has the idea to spray some contact cleaner into the solenoid to dissolve seized up grease, use compressed air to remove residue and then apply some sewing machine oil. Am I on the right track? It is very difficult to get to the solenoid "piston", as you can't take it out of the solenoid.
Cheers and merry Christmas, Søren Hammer
									    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
									        Dillen
								                - Joined on 02-14-2007
								                - Copenhagen / Denmark
								                - Posts 5,008
										    Re: Beogram 4004 solenoid
										    Søren please...
WD40 contains acid in some form. It's good for (and meant for) losening rusty bolts on a car. It has nothing to do inside stereo, let alone in your livingroom !
Contact cleaner is de-oxidizing. It's for - cleaning contacts, nothing else !
The piston is not inside the solenoid and the plunger inside the solenoid can be removed but that's rarely needed, the problem is almost always somewhere else.
A tangential Beogram is a fine piece of mechanics and electronics, please consider having it serviced properly, trial and error won't get a tangential working. As a minimum, consult the service manual for lubrication charts and adjustments.
									        Søren Hammer
								                - Esbjerg/Denmark
								                - Posts 554
										    I have tried to persuade my father not to use WD-40 or contact cleaner, as i have the same opinion as you. I have looked in the service manual, I understand the mechanical workings of the the section, as well as the lubrication charts. The dampening cylinder is working fine, I had thought that it was the classic fault of a frozen dampening cylinder, but the problem lies in the solenoid. There is simply too much friction.
-Søren
									        Dillen
								                - Posts 5,008
										    Check the solenoid arms pivot points around the solenoid and also inside the carriage housing.
									        tournedos
								                - Joined on 12-08-2007
								                - Finland
								                - Posts 5,808
										    Another point to check might be the small spring that tensions the lifting arm (part no. 219 at least in 4002/6000 service manual). In my 4004, the other end of it was dislocated and the arm just wouldn't rise at a proper speed even after I had freed everything else.
But if you can see the actual solenoid piston not moving fast enough, this will not be the (only) problem.
									        Søren Hammer
								                - Esbjerg/Denmark
								                - Posts 554
										    I had lubricated every moving part, part no. 219 was moving fine, but I had found out that the problem was the bolt holding part no. 190. It had to be disassemblied and lubricated inside. After putting the thing together it began to work like new. Thanks for the help ^^
									        Medogsfat
								                - Joined on 02-21-2007
								                - *Moderator* Leeds, Yorkshire
								                - Posts 4,045
										    Nice - it's always a huge relief when it turns out to be nothing more than a bit of lubrication.
Chris.
									        Søren Hammer
								                - Esbjerg/Denmark
								                - Posts 554
										    Indeed. I thought that the pivot point of the arm (part #190) was a normal loose bearing like the parrallel arm, but it was some sort of chrome-washer. It was dirty and needed lubrication, and the circlip holding it was slightly bent. Apparently enough friction to slow down the whole mechanism.
-Søren
        Page 1 of 1 (9 items)
