Sorry, Stefan, a little misunderstanding. I mean the Beo5-display and not my BV display.
My experience with the ClarkeTech STB third-party.xml was that all the commands were bundled on the Beo5-display as buttons (OK, Mute, Channel+-, Volume +-). That's not the way I want to use the Beo5.
Of course, using the PUC .xml is a better solution, but my BlueRay player is alredy using the PUC-'place'. Switching from one PUC to another is not the most comfortable option! My BC 6-26 has only one IR-output!
Again my question: is it possible to translate or convert the Humax iCord HD PUC-.xml in any way to control that STB direct without a PUC/IR-eye and with the use of most keys form the beo5-wheel?
Hope this is a better explanation...
Pim
