Hi there,
I am new to this Forum and already have a question
Somehow I can't get my Humax PVR9150T to work with my Beo5! I just don't know what I'm doing wrong...? In the Beo5 config tool, I add the Humax PVR9200T to my configuration (there is no code specifically for the 9150 but i have been told they work the same way), I get all the correct buttons under the DTV menu - easy - but nothing happens!
I should say that it is connected to my BV8 via a scart cable to AV2 (even though I have tried connecting to AV1, too).
Could someone please send me a step-by-step instructions (for dummies!) how I can get this to work? Is there anything else I need to do apart from programming the Beo5 - cables, settings on the BV8 or STB, etc.?
Sorry if the question is really stupid, so far everything I have programmed works fine but somehow this one's giving me sleepless nights as I just can't figure out why it won't work!
Many thanks!
clueless
