Latest post 09-11-2009 6:02 AM by stefan. 3 replies.
Page 1 of 1 (4 items)
  • 09-08-2009 1:41 AM
    Beo5 and Sanyo PLV-Z2000
    I am new to this forum. May I know if anyone can help on how/where to download XML configuration file for Beo5 to control Sanyo PLV-Z2000 projector, all I need is on/off control. Sanyo's projector can't be controlled from Beo System 3 thus I need to use Beo5 as universal remote to turn on TV (Beovision- Done), DVD player (Pioneer BDP LX71 - Done) , projector (Sanyo - need help) and projector screen (Still working on it) all at once.
    I contacted the official B&O dealer in HK but they don't seem to hv the setup so they actually me to help, whcih I found this site a while ago.
    Tks in advance
    George Ngan
  • 09-08-2009 3:12 AM In reply to
    Re: Beo5 and Sanyo PLV-Z2000
    George,
    A very warm welcome to Beoworld.
    Have you reviewed the Beo5 Infromation and Resource Centre HERE where there is a Sanyo projector XML file
    Regards Keith....
  • 09-09-2009 11:19 AM In reply to
    I have the same setup as you, and emailed my dealer the XML for Beo5 control of the Sanyo projector (since I don't have the config software myself).  He asked B&O HQ (in the US) and they said I'd need a hardware update to my Beo5 to send out the appropriate IR signal for this.  They also seemed suspicious that I was supplying my own XML for this, and seemed uneasy at the whole idea.  I never got back to exploring the idea since then, which was a few months ago.
    For direct BS3 support, they are asking $500 and for the remote to be sent to their US headquarters in Chicago.  It's always possible that someone will spring for this and we'll all benefit (assuming it'd then be available world-wide).  Or, if enough people want this, I suppose we could pool our money.
    -- Paul
    ngangeorge:
    Tks in advance
    George Ngan
  • 09-11-2009 6:02 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    A lot of BV7 /BS3 owners here are conrolling their "cinemas" with a Lintronic box -238. www.lintronic.dk You can connect the box to your BS3 cinema outputs and trigger your projector, screen, lights, blinds, pop corn machines... just with one button on Beo5: Cinema. Works also with Sanyo. http://www.lintronic.dk/asp/LinTronic_SupportedDevices.asp. So no need to update/reprogram your Beo5. You will find a lot information how to do that in the forum.
    Hope this helps
    Stefan
