Latest post 09-07-2009 5:16 PM by Seanie_230. 19 replies.
Page 1 of 1 (20 items)
  • 01-07-2009 5:41 PM
    SW: Latest BV 7 version
    Dear All:
    What's the latest version of the BV 7 MkIII software?  The area's only B&O certified technicians upgraded the SW to day to V 4.71.  Is this the latest version?  If not am I going to encounter any issues?
    Thank you,
    Dario
    When I hear music, I fear no danger. I see no foe... Thoreau
    Filed under:
  • 01-07-2009 5:43 PM In reply to
    Re: SW: Latest BV 7 version
    I think the latest version is 5.02.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 01-07-2009 5:54 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Yes, the latest is 5.02. With black menus and support for Beomaster 5.
    Stefan
  • 01-07-2009 11:23 PM In reply to
    Thank you everyone.  The BS 9K was taken away for some repairs.  I will ask the technician next time he is in to update to the latest SW.  Although, I doubt I will be getting the BS 5.
    The idea is good; the amount of HD space is just poor.  The thing needs at minimum  1 terabyte of space.
    Dario
  • 01-08-2009 1:17 AM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Latest SW is 5.04, build 435, released yesterday.
    Quim
  • 01-08-2009 5:47 AM In reply to
    I have 5.02 but over the xmas break discovered if you watch sky in link room when the main tv(beovision 7) is turned off the link room tv displays message this display does not support hdcp. B&O tell me there was new software on the way to fix this problem with 5.02.
    Do you know if 5.04,build 435 fixes this problem and what other changes there are? thanks
  • 01-08-2009 6:43 AM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    Paul, if you find out this info, let me know. As you know, I share the dodgy link room problem :(
    Unfortunately my dealer seems to be on a sales drive and isn't getting back to me with any info about this problem. More fool them.
  • 01-09-2009 7:46 AM In reply to
    Quim,
     is the software level the same for BV7-32 and BV7-40 (both MK-III I suppose)?
    And if not, what is the software level for BV7-32?
    Piet
  • 01-09-2009 8:18 AM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    Piet,
    The lastest SW for the BV7-32 Mk3 is 7.84 for the TV SW and 7.74 for M2 SW.
    SW 5.04 is for BV7-40 Mk3, BV9, BV4 and Beosystem 3 with DVB HD.
    Quim
  • 01-09-2009 8:59 AM In reply to
    Thanks Quim,
    I have ordered a BV7-32 to replace my Avant 28" (50 Hz type). I can't wait.........I have to wait; it will be delivered after january 15.
    Piet
  • 01-09-2009 9:00 AM In reply to
    what ist DVB HD and what can I do with this modul.
  • 01-09-2009 1:07 PM In reply to
    Quim
    What is the latest software release for the BV7-40 mark ii?  As far as I am aware, I have not had any sw upgrades installed.  Do I need to worry?
  • 01-09-2009 1:20 PM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    The lastest SW for the BV7-40 Mk2 is the same I said for the BV7-32 Mk3, 7.84 and 7.74. If your TV works fine, I would not worry for a SW update.
    Regards
    Quim
  • 01-10-2009 10:14 AM In reply to
    Thanks, Quim
  • 03-06-2009 3:08 AM In reply to
    Re: SW: Latest BV 7 version?
    how can I find out the SW version of my TV?
  • 03-06-2009 6:36 AM In reply to
    Upgraded my 7-40 mk3 Wednesday to 5.08
    Richard
  • 03-06-2009 8:26 AM In reply to
    • GANGO
    • Not Ranked
    • Joined on 04-17-2007
    • italy
    • Posts 48
    upgraded bs3(bv9) 10 days ago with sw. 5.08. everythings fine now...finally!
    gango
  • 09-06-2009 3:24 PM In reply to
    • Lene
    • Not Ranked
    • Joined on 10-08-2007
    • Posts 7
    bulldog:
    MENU -> Options -> Press 'RED' followed by 'GO' -> Status Info      and voila
  • 09-06-2009 5:15 PM In reply to
    last version (on sept. 2009) is for BV7-40 MKIII and MKIV ist 6.11
  • 09-07-2009 5:16 PM In reply to
    • Seanie_230
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    ohhh hi there
    what is contained within 6.11 from 5.08a???
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
