The beoport and beolink wireless are not compatible. This means that the connection between the BS and the BeoPort must be hardwired ML cable, not the beolink wireless. You can use a beolink wireless to distribute music from the beoport to link rooms.
You could use an airport express (and connect it to the AUX port of the bs), and it would be a lot cheaper.
Stan
