Latest post 09-13-2009 8:46 AM by RobN. 4 replies.
Page 1 of 1 (5 items)
  • 09-12-2009 11:48 AM
    Forum - Snow Leopard - Safari
    I'm typing this on a new MacBook Pro with Snow Leopard.
    This time I can browse the forum with Safari. Before I had to switch my browser to Firefox.
    Something changed? Or is it my MacBook?
  • 09-12-2009 12:44 PM In reply to
    Re: Forum - Snow Leopard - Safari
    I have used Safari to read the forum for a long time.  I haven't seen any difference browsing Beoworld with the Snow Leopard version.  I have installed Snow Leopard along with the new iTunes 9 on my MacBook also.  Everything runs faster and Wifi works better among other things.
    What did you notice was different in Safari?
    Beosound 5 BL9 BC2 BL8000 Beovision 7 BL6002  BL11
  • 09-12-2009 2:09 PM In reply to
    I have been using Safari on this website for years, without any problems... Good that SL fixed your problem.
  • 09-12-2009 4:53 PM In reply to
    I have just loaded Snow Leopard
    I had two glicthes that I noticed:
    - my eyeTV needed a release upgrade ... which I did
    - my Beoconnect brings up an login screen for something called iTunesDroper ... but since I have not purchased a BM5 I ignore it
    Everything else is fine
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 09-13-2009 8:46 AM In reply to
    • RobN
    • Not Ranked
    • Joined on 05-15-2007
    • London, UK
    • Posts 57
    • Gold Member
    Hi Coolskin,
    I've been browsing this forum for ages with Safari so I don't think the upgrade to SL was the cause, perhaps it reset some setting in Safari to factory settings whilst upgrading?
    Glad it's working for you as Safari is really quick.
    Best
    Rob
    BV7-32, BL8000, BL2, BL6000, Humax, AppleTV3, MX4200, V8000, Humax, BS3200, BL6000, BL4000, BeoPort, MacMini+DACmagic
