Latest post 08-29-2009 1:49 PM by raveny. 2 replies.
Page 1 of 1 (3 items)
  • 08-29-2009 9:45 AM
    Vertical pixel error on BV4
    my BV4 has vertical pixel errors on the right side with dark backrounds, but only with AppleTV or BluRay. It's only one pixel column and my dealer has the same issue!
    Does anyone know more about this?
  • 08-29-2009 11:55 AM In reply to
    • expoman
    • Top 500 Contributor
    • Joined on 04-17-2007
    • United States
    • Posts 222
    Re: Vertical pixel error on BV4
    It sounds like an overscan line caused by the source.  The Beosystem 3 will let you adjust the black frame of the picture to cover it.  What are you using to drive the BV4?
  • 08-29-2009 1:49 PM In reply to
    I have a BeoSystem 3 connect with an AppleTV and Pioneer BL Player. How can I adjust the frame?
