I seem to get contradictory information from my dealer, so I have to seek the truth among my forum friends
I have a BV8 32" with a system module installed, giving me ML and DVB-T. The guy installing the set said that with the system module installed I will only have one STB-C to use.
Is that really correct? I have not had the possibility to check if both in fact is occupied (one is for sure connected to my cable box, and works fine).
Now, the dealer says that I do have both STB-C:s available.
Can anyone confirm what is correct?
Thanks,
Claes
_____________
Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
1:st prize winner Beoworld January Price Draw.
