Hi everyone
I need your help before contacting my dealer.
I bought a pair of BL9´s and Bl3´s for my BV 7-32 a little while ago. I am abslolutly thrilled by the sound this system provides. However, last weekend when listning to my 9´s in speaker 2 mode i found that it seemed one speaker(R) player louder and with way more bass than the other one(L). First i thought it was simply the balance beeing odd, but this was not the case. Then i checked for the speakerlevels in the soundsetup menue on my tv, nothing there either. SO i started wondering if i ruined one of my speakers so tryed to swich them around. The problem didnt move with the speakers, so it isnt the speaker. then i tried replacing the powerlinkcables, however that didnt help either. At last i swiched the frontcables in the sockets on my tv, no change either....
To be honest i am a bit confused about this... Cant seem to find out what can be the problem. Am i missing somthing??. Tried with different types of music and the problem still seems to be there. One speaker is placed in a corner and the other by a wall so i moved them out in the room when testing making sure that they were both set the same way. I really cant figure out how to solve this... maybe it is my hearing but had no problem whatsoever before. When listening to music in speaker 4 toning down the frontspeakers, the rearspeaker in the same side(R) seems to provide more power aswell. My conclusion is that somhow my right chanel on my tv provides more boost both to front and rear, than my left channel??? Can this be??
Please help me, i am getting used to your help so please dont let me down on this one
									    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
