Latest post 08-19-2009 4:34 PM by JC. 7 replies.
Page 1 of 1 (8 items)
  • 08-14-2009 4:40 PM
    Moving Beovision 7-40 with floor stand
    How do you recommend to move this TV, is it possible to lift it - and where should we grip it.
    SAKRUN
    Filed under:
  • 08-15-2009 9:55 AM In reply to
    Re: Moving Beovision 7-40 with floor stand
    The easiest way is to simply remove it from the stand before moving it. Moving everything in one go is IMO to risky and hard.
    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
  • 08-16-2009 10:55 AM In reply to
    Seems to be much work just for moving TV 30 cm?
  • 08-16-2009 1:59 PM In reply to
    • Hungedu
    • Top 500 Contributor
    • Joined on 08-08-2009
    • Ambergris Caye, Belize
    • Posts 128
    Definitely remove the TV from its stand first, and then move it in two pieces. Trying to lift the BV-7 with stand will risk bending the aluminum face plate on the motorized base. It's flimsy and easily bent - not like the first generation BS-9000 floor stands that were solid, polished aluminum.
    BeoVision 7-55 3D, BeoSound 9000, BeoSound 8, BeoLab 7-6, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, LC-1, BeoTime (analog clock), Form 1 headphones, Beo 4 remote.
  • 08-16-2009 2:20 PM In reply to
    • JC
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Yorkshire / UK
    • Posts 621
    Tip it backwards very carefully, slip a bedsheet folded as thick as possible underneath. Tip it forward and slide sheet fully under. Then slide into position and reverse process.
     Jonnie
  • 08-18-2009 3:18 PM In reply to
    JC:
     Jonnie
    Wow JC, good tip, did not think of that one at all...Wonder if it also works with BV4-103 :-)
  • 08-19-2009 12:57 PM In reply to
    Thanks!!
  • 08-19-2009 4:34 PM In reply to
    • JC
    • Yorkshire / UK
    • Posts 621
    Very big shett and 4 people!!!!!!!!Wink
    Jonnie
