I recently acquired one RX2 record deck, unfortunately its an us device, so it needs 110 volts.
Since I have one (220v) Beoram 5005 left for parts, I thought maybe I can use the power supply for the RX2.
It looks pretty much similar, could not find any difference when comparing these 2 power supplys.
Does anybody know if it is possible just to solder the 5005's power supply in the RX2 or if there are more things to change (then I will leave it as it is and use converter)
