Latest post 08-09-2009 10:42 AM by Chrisreunion. 1 replies.
Page 1 of 1 (2 items)
  • 08-07-2009 5:09 AM
    • Ransom
    • Not Ranked
    • Joined on 08-07-2009
    • Posts 2
    Customize Radiostations on BeoMaster 5
    Hi everybody,
    I recently bought a BeoMaster 5 and I was wondering, if I could define my own radiostations (by providing a link to a webstream)? I already looked at the BeoMaster application running on the BeoMasters operating system, but I didn't find any possibility to change the set of radiostations. Seems you can't change it because its hardcoded in the application.
    Does anybody have any experience with that issue or maybe even know a workaround?
    Thanks in advance.
    Cheers,
    Ransom
  • 08-09-2009 10:42 AM In reply to
    Re: Customize Radiostations on BeoMaster 5
    If you have your BeoMaster in a PC configuration, unfortunately you can't add radio stations that are not in the B&O list, however with a Mac & Itunes, you can, since the radio stations come from Itunes.Hmm
    Reunion Island is greeting you!
