Latest post 07-26-2009 8:48 AM by Quim43. 3 replies.
Page 1 of 1 (4 items)
  • 07-25-2009 7:17 PM
    • k984942
    • Top 500 Contributor
    • Joined on 11-10-2008
    • London, UK
    • Posts 194
    Lights & TV on/off?
    Can anyone help me create an all off button that will switch off my Avant and lights, and an all on which will switch on the lights and the tv (DTV)
    I'm sure its simple to do but I'm having trouble!
    32" RF VCR Avant, 2 x 28" VCR Avant, DVD1, Beocom 6000, Beo5, A9 Keyring!
  • 07-26-2009 5:49 AM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Re: Lights & TV on/off?
    Hi
    There is a trick you can do. Go to the View tab end press the buttons on the virtual Beo5 to do what you want. Keep the IR commands you will see in the window and then, go to the Edit tab and create a button with all those commands you got.
    I hope it helps.
    Quim
  • 07-26-2009 7:22 AM In reply to
    • k984942
    • London, UK
    • Posts 194
    Great suggestion Quim43.
    Job done!
    Now all I need to do is to work out how to add P-In-P to the Beo5 for my Avant....
  • 07-26-2009 8:48 AM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    Glad it worked. For PandP, there is another trick. Create a new zone, add a BV7 and your other video sources to this zone. Go to Edit tab and copy the PandP button. Place this button on your main zone. I think it may work.
    Quim
