Latest post 07-21-2009 2:53 PM by moxxey. 6 replies.
Page 1 of 1 (7 items)
  • 07-21-2009 9:17 AM
    • Aitch
    • Not Ranked
    • Joined on 04-30-2007
    • Posts 2
    Analoque changeover/ Sky and sky plus
    Currently have Avant with Sky plus and sometimes record two programmes at the same time. When this happens I can switch to analoque and watch something else. However, with the analoque signal being switched off shortly (early August), can I use my original Sky Box (in conjunction with the Sky+) to watch a different programme whilst the Sky+ records. Is this possible or will there be a conflict?
    Thanks, Aitch
  • 07-21-2009 9:23 AM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Re: Analoque changeover/ Sky and sky plus
    A small and discrete freeview box might be neater (using your now surplus antenna cable).
  • 07-21-2009 9:32 AM In reply to
    • Aitch
    • Not Ranked
    • Posts 2
    Thanks for that. Hadn't thought to go that way, and as you say would be a little more discrete.
    Aitch
  • 07-21-2009 10:15 AM In reply to
    • Puncher
    • Posts 9,588
    Happy to be of assistanceSmile
  • 07-21-2009 12:23 PM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    Aitch:
    If I understand you correctly, you can do that with Sky+ anyhow, using one box? Often I'll be watching one TV programme, realise something more important is on another channel, decide to record the rest of the TV programme and will switch across to the other channel. So you can watch one channel and record another at the same time.
  • 07-21-2009 12:45 PM In reply to
    • Puncher
    • Posts 9,588
    moxxey:
    Aitch:
    My understanding was to record two programmes simultaneously, while watching neither and be able to watch terrestrial TV (or other non-Sky+ TV source) at the same time.
  • 07-21-2009 2:53 PM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    Puncher:
    Hmmm. Perhaps you can do this if you had Sky+ and the built-in DTV module and you watched that whilst Sky records. I don't know, I've never tried it (although I will do).
    I don't know if the Sky HD box is capable of recording two HD programmes to the drive at the same time, due to the amount of data it would have to write to the drive, simultaneously.
