Latest post 07-19-2009 2:35 PM by Eugene. 4 replies.
Page 1 of 1 (5 items)
  • 07-19-2009 11:33 AM
    Foam 'Gaskets' on a CX100
    I  am currently restoring a pair of CX100's that I bought for a song from ebay that have extensive foam rot.
    When I removed the drivers the  foam that sits between the speaker drivers and the body of the speakers was missing. I am not sure what you call them but if they were on a car you would call them gaskets, hence the title of the post!
    Does anyone know if these are still available? Alternatively does anyone have any suggestions for what I could use to make my own?
    Many thanks
    Simon
  • 07-19-2009 11:48 AM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Re: Foam 'Gaskets' on a CX100
    try a local foam merchant - should be listed in yellow pages - should have soething near enough then use scissors for the outer shape and something round of the approx diam reqd and a scalpel to trace/cut the central round bit - sound difficult when written down but dead easy in 12" to the foot real life!
    t
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 07-19-2009 12:02 PM In reply to
    i agree, just cut some similar material to the approximate shape. I suppose their only purpose is to damp high frequency reflections from the fret cage / enclosure edges, and that is by no means critical.
    -mika
  • 07-19-2009 12:30 PM In reply to
    Thanks for the  replies!
    Just ordered a sheet of this, I'll let you know how I get on.
    Foam sheet
    Simon
  • 07-19-2009 2:35 PM In reply to
    Probably work just fine. I would have walked over to the auto-parts store myself.
    You had asked to see how I got along with my recent refoam job and so here are the results.
    From this
    To This
    I use the rubber surrounds from Good-Hifi instead of the foam. I liked the result I also replaced the crossover caps with newer poly caps.
