Latest post 07-21-2009 11:24 AM by Jandyt. 7 replies.
Page 1 of 1 (8 items)
  • 07-21-2009 5:08 AM
    Datalink compatibility CD3300 & BM3000?
    Hi all!
    I have a quick question, I'd like a CD player with my beomaster 3000 (1986's) and beogram 3000, if I plug a beogram CD3300 into the tape socket of the BM3000, will they 'communicate', or will only a tape deck (eg BC2000) work?
    Thanks in advance!
    CJLaughing
  • 07-21-2009 10:46 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Datalink compatibility CD3300 & BM3000?
    Hmmmm, I wasn't sure about that, so I went onto the Datalink page of Beotech to see.
    It would appear that the Beomaster 3000 and the Beogram CD3300  are indeed, Datalink compatible.
    Have a look yourself, here.
    Andy T.
    Poor me, never win owt!
  • 07-21-2009 10:58 AM In reply to
    Thanks Andy! I forgot about those pages, but the answer there 's not yet definitive...
    I just tried if my BG3000 would start when pressing TP/the BM3000 would go on TP with the BG plugged in to the TP socket, there was no communication.
    Is the datalink signal device specific, or in other words, will a TP socket respond to the signal of a CD player and vice versa?
    I used to have a BC2000, it communicated fine with the BM3000 via the TP socket.
    Thank you!Laughing
  • 07-21-2009 11:03 AM In reply to
    • Jandyt
    • Posts 13,004
    CJ, is the Tape socket 7 or 5 pin DIN?
    Do you already have a CD3300 to try?
  • 07-21-2009 11:13 AM In reply to
    The tape socket is a 7 pin DIN.
    I don't have a CD3300, otherwise I would have tried alreadyWink
    I'm really in love with the datalink system so I'm trying to find a CD player that will match the BM3000 ánd will datalink with it. If there is no such thing I'll start looking out for a new beosystem which does include a datalinkable CD player.
    Laughing
  • 07-21-2009 11:14 AM In reply to
    • Jandyt
    • Posts 13,004
    Bad news (I think) CJ.
    I just had a look at the Datalink system builder chart in the Jarman book. It says
    "Beomasters marked with  X  do not have a Datalink connection for a compact disc player.  For these models, the Beogram CD X (also marked  X  ), CDX 2 or a CD 50 fitted with the IR sensor kit are recommended.
    Your BM 3000 is marked with an  X  . Sad
  • 07-21-2009 11:15 AM In reply to
    Oh, bugger! Well, I kind of expected that... nevermind, reason to start looking out for a system 3500/4500 or one of those beautiful BC9500's!
    Thanks for your quick and very helpful reply's!
    Laughing
  • 07-21-2009 11:24 AM In reply to
    • Jandyt
    • Posts 13,004
    Smile Don't forget the wonderful Beosystem 7000!Wink  Take care mate.
    Andy T.
