Latest post 07-18-2009 2:05 PM by Seanie_230. 2 replies.
Page 1 of 1 (3 items)
  • 07-18-2009 12:47 PM
    no sound with sky+hd connected to beovision 7
    Have just had a sky+ hd box installed. of course sky engineer only had hdmi cable so didnt complete installation but left me to go buy a dvi/i connector. that is now connected and picture comes through fine. but no sound.  have tried connecting audio l-r cables from sky box to av4 socket on bv7, and also tried a coaxial digital cable from digital out on sjy box to a1 on bv7.  still no sound.
    any suggestions?
    peter
    Filed under:
  • 07-18-2009 1:44 PM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    Re: no sound with sky+hd connected to beovision 7
    The problem with DVI is that it can't handle sound, as you've found out :(
    The audio L/R cables should work though. Have you selected AV4 as your Sky option within your connection settings and then sound input -> YPdPr? Without this, it won't recognise sound through the AV4 input.
  • 07-18-2009 2:05 PM In reply to
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    if you have a BV7 MK2 u need to use a scart lead for sound
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
