Hi there
The other day I noticed that my Beomaster 5000 is humming slightly, both when turned off and when on. There is no hum in the output signal, one can only hear the hum when one lays the ear to the Beomaster. Also I noticed that the beomaster is developing some heat (not that much, but some), even when it is turned off. How worried should I be about this? Obviously the amp is more than 20 years old, so perhaps a check at a workshop is due, but on the other hand, it is working beautifully when turned on and playing.
Thanks for your advise
Chr.
