Latest post 07-12-2009 3:59 PM by Dillen. 3 replies.
Page 1 of 1 (4 items)
  • 07-12-2009 3:26 AM
    • Kevin
    • Not Ranked
    • Joined on 03-02-2009
    • San Francisco
    • Posts 73
    Beogram 8002 arm indexing
    Hi all.  I have a BG8002.  Its as cherry as these units can get but the arm does land a bit too far into the record.  Is there an adjustment screw somewhere that I can adjust myself, or is there some electronic part that needs replacing?  Feedback?  Thanks very much.
    BeoSound 9000, Beolab 8000, BeoLab 4000.   Beogram 4002/Grado Gold Amina conversion.
  • 07-12-2009 5:58 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beogram 8002 arm indexing
    You can adjust this by losening and relocating the switch under the black metal cover.
    In your case it will have to be moved a little to the right.
  • 07-12-2009 2:53 PM In reply to
    • Kevin
    • Not Ranked
    • San Francisco
    • Posts 73
    Dillen:
    Thanks Martin.  All I could find was something held down (pretty tightly) by a phillips screw.  Is that it?
  • 07-12-2009 3:59 PM In reply to
    • Dillen
    • Posts 5,008
    It's a black box with wires running to it and a metal arm coming out towards the rear of the Beogram that
    the carriage hit when parked home.
