nmartin771:
Thanks Kokomo
So, I need 5pin DIN plug ?
Others may have the PIN configurations to hand, but I believe although the plug may be a 5 pin only the left/right audio will be wired to the necessary pins in the plug. The DIN plug, like the scart, has certain pins designated to appropriate functions so you can be pretty certain that a din - phono lead will be wired appropriately. If the DIN plug has fewer pins but is still wired to twin phonos that will be OK.
These leads should be widely available in shops also internet of course.
I'm sure you know this but worth a mention I think, from your photo you seem to need din - phono female. Make sure you don't make the error of getting din - phono male
