Latest post 07-06-2009 7:28 AM by tournedos. 2 replies.
Page 1 of 1 (3 items)
  • 07-01-2009 4:28 AM
    Beomedia 1 and scart sockets on Biovison Avant TV
    Can someone please tell me how I get the PC option onto my beo4 remote, I have pressed list and gone through the options but cant see pc as an option. Second question I seem to be having problems getting my b and o DVD player to play through the avant also. I have a set top box plugged into the AUX Scart and the DVD player plugged in to the correct scart socket, also the options are correctly selected in the menu connections of the avant tv, however the dvd will not play.
  • 07-06-2009 4:35 AM In reply to
    Re: Beomedia 1 and scart sockets on Biovison Advant TV
    I see, looks like no one has any idea ok.
  • 07-06-2009 7:28 AM In reply to
    Perhaps people just objected with your spelling of Beovision Avant Big Smile
    Seriously - you must have one of the earlier model Beo4's. They don't have PC or any of its derivatives (L-PC and so on). On a Beolink 1000, you could send the same command with (TV) SHIFT-STORE, but I'm not aware of a similar trick on Beo4.... perhaps someone else knows?
    I'm sorry I can't help you with your second question.
    -mika
