Latest post 06-15-2009 6:02 AM by MikaelB. 7 replies.
Page 1 of 1 (8 items)
  • 06-13-2009 1:06 PM
    • mirror
    • Not Ranked
    • Joined on 06-05-2009
    • Posts 8
    RL 140 on the wall
    Hallo there!
    Wath do i need to hang the RL 140 on the wall?
  • 06-13-2009 1:58 PM In reply to
    Re: RL 140 on the wall
    2 foot thick stone ones should just about do it! Big Smile
    Train Hard - Run Fast - Hit to Kill!!!
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    You really need the original B&O wall brackets which are quite difficult to find these days - and a very strong wall to hang them on!
    Chris.
  • 06-13-2009 2:23 PM In reply to
    Medogsfat:
    Chris.
    Not so strong!! I hung mine on two houses and they both had studwork walls. As long as one screw is into a stud  then they are fine.
    You do need the 140 wall brackets  which are different to the 45/60 brackets and as Chris says are difficult to find these days.
    Regards Graham
  • 06-13-2009 3:05 PM In reply to
    joeyboygolf:
    If you want to rotate them here and there, yes - but if fixed perpendicular to the wall is OK, there are other solutions. For a pair of RL6000s, I got two perforated T-shaped steel plates (normally used for reinforcing wood constructs) from a hardware store. A pair of the holes accepted two bolts to the speaker rear mount directly, and the rest was only two hooks on the wall...
    And the RL140/7000 aren't that heavy, only 15 kg a piece. An MX4000 with a wall stand weighs much more, and think of the wall mount shelves people have loaded with books...
    -mika
  • 06-13-2009 3:41 PM In reply to
    • mirror
    • Not Ranked
    • Posts 8
    My ges was a reply: Two RL 140 and a wall...but i am happy with what i reed. I am working as a mecanik and i will do something there that i kan bolt on the backside and something to hok it on. Thanks.
    best regards
    tommy in Sweden
  • 06-14-2009 6:04 AM In reply to
    • Kokomo
    • Top 100 Contributor
    • Joined on 08-21-2007
    • Spain
    • Posts 618
    mirror:
    Hallo there!
    Just two points:-
    1. Be aware that bass/mid performance can be affected by positioning of speakers on a wall. Some models of speaker are designed for this, others not. I know the RLs were available with wall brackets, but that doesn't mean the sound would not be affected.
    2. Unless the brackets permit the speakers to be 'angled inwards ', the stereo 'picture' would be unfocussed in a chosen listening position.
  • 06-15-2009 6:02 AM In reply to
    • MikaelB
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Herning, Denmark
    • Posts 191
    As mentioned the original wall mounts are a way to go.
    I used to have a pair of RL 140, with floor stands. The bracket that held the speaker on the floor stand could be taken of and mounted on the wall. I created my own seeling/wall mount solution from wood, and just mounted the bracket from the floor stand on it. It worked fine.
    I agree you need a stron wall. You also need to find a way to angle the brackets on the wall, if you want to angle the speakers towards the listening position.
    /MikaelB
