Latest post 06-15-2009 1:17 AM by beoaus. 1 replies.
Page 1 of 1 (2 items)
  • 05-24-2009 10:15 PM
    • beoaus
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Melbourne, Australia
    • Posts 445
    BV7 40 MK11 link problems
    I have lost access to A.AUX (turntable), DVD2 (Wii) and CAMERA (IPod) in link rooms. Other commands work like VAUX, CD, VTAPE DVD etc?  I had a firmware update a little while ago though I can't remember if this problem co-incided with that date.... When I select the commands the link equipment turns on through I have no video or audio.....
    I have tried powering off and disconnecting ML for over 30mins... No success...
    Any suggestions most appreciated.
    beoaus
  • 06-15-2009 1:17 AM In reply to
    • beoaus
    • Posts 445
    Re: BV7 40 MK11 link problems
    Problem solved. It was not the software update.
    Started the slave TV in this case a MX7000 before the BS9000, and other link systems.  The BV7 (Video Master) was the last. Seems the order fixed the problem. Complete fluke that I found the resolution.
    beoaus.
