Latest post 06-14-2009 8:06 AM by Friedmett. 4 replies.
Page 1 of 1 (5 items)
  • 06-13-2009 4:28 PM
    • mirror
    • Not Ranked
    • Joined on 06-05-2009
    • Posts 8
    Which CD
    I have now a Beocenter 7007 and RL 140 loudspeakers. And i wonder...which CD, not to expensive, am i going to thoose?
  • 06-13-2009 4:54 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Which CD
    Any CD player will work OK but if you want a B&O one then the ONLY choice is a CDX really. Absolutely perfect with this range of Beocenters in both sound & design. It isn't often I make a sweeping comment like this but I'm fairly confident the rest of the membership will back me up on thisBig Smile
    Chris.
  • 06-13-2009 5:31 PM In reply to
    Re: Which CD
    Yep - Chris is right. I have a CDX that I use with a Beomaster 8000 and it's a wonderful machine :)
  • 06-13-2009 7:20 PM In reply to
    Re: Which CD
    My next door neighbour has one of these with a Beogram CD3500 - also a good visual match and newer but if it was me I would go for a CDX
    Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
  • 06-14-2009 8:06 AM In reply to
    Re: Which CD
    I still use my CDX with a Beomaster 8000. It sounds awesome despite the age.
    It sounds a bit more dark since it's only 14bits but it's basically a workhorse.
    I got a CD6500 too and I can't say the CDX is better but for your system you can't go wrong with one.
