Latest post 09-06-2008 3:31 AM by moxxey. 2 replies.
Page 1 of 1 (3 items)
  • 09-05-2008 6:06 PM
    BV7 + Wii component = stand runs wild
    Hi guys.
    I need help! Or suggestions..
    I've conncted a Wii via component to my BV7 MkIII. After this my stand position is acting VERY strange. It's become autonomous.. Example: When I turn off the TV it'll go to the utmost right position. Turn it back on and it'll go to the full left position. Turn the DVD on - it might go slightly left.. if you get the picture.. If I try to (via the standard menu option) reposition the stand it will respond - but as soon as I exit the menu it goes "scr_w you - I'll go to what ever position I please.." Same goes if I adjust via the remote..
    Can anybody help?
    Best regards
    Sundby
  • 09-06-2008 3:05 AM In reply to
    Re: BV7 + Wii component = stand runs wild
    Hi there - I had the same problem. This bug was fixed in firmware 4 and greater. It was a feature of 3.5. I would put up with the bug for a few more weeks while B&O's QA procedures for software improve as 4.24 actually has more bugs that surface everyday. Although I would say that picture quality is better than 3.5.
     Bugs that I am experiencing in 4.24
    - When Sky HD box is connected to BV7 with HDMI and Scart (for the masterlink capabilities) then seeing SKY on remote Beovisions intermittently fails (whilst sound continues).
     - All Beovisions in a Link system can fail to startup/respond from the Beo4 or Beo5.
     There is of course of seperate thread to the 4.24 issues that are worth following to find out when 4.3 become available.
     Best, Mark.
  • 09-06-2008 3:31 AM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    Add this discussion to the thread:
    http://forum.beoworld.org/forums/thread/130955.aspx
