Latest post 06-27-2009 8:04 AM by k984942. 2 replies.
Page 1 of 1 (3 items)
  • 06-27-2009 7:34 AM
    • k984942
    • Top 500 Contributor
    • Joined on 11-10-2008
    • London, UK
    • Posts 194
    Control of Bionaire BT16
    Hi All,
    Could anyone please help me control this remote controlled tower fan using my Beo5?
    32" RF VCR Avant, 2 x 28" VCR Avant, DVD1, Beocom 6000, Beo5, A9 Keyring!
  • 06-27-2009 8:00 AM In reply to
    Re: Control of Bionaire BT16
    If you have the original remote control, then the codes can be captured and an XML file created.
    Regards Keith....
  • 06-27-2009 8:04 AM In reply to
    • k984942
    • London, UK
    • Posts 194
    I do have the the original remote Keith. I problem is I don't have the equipment or knowledge on how to create XML files!
    I believe you need a device to capture the IR codes, but with the Macbook Pro I have there is no IR port. I don't have a palm pilot or anything else like that either.
    Help!
