Hi!
I am new here and i am not so god at englich but i give it a try.
I have precisly get a beocenter 7007. Its a very nice one but...the volumpot dasent work. The
disply stands at 2.8 and there it is.
best regards
tommy
Have you got the remote? If that works, the problem could be as simple as a loose wire.
I have the remote...with a bad battery but the diod lights green.
