Latest post 06-02-2009 4:07 PM by KingOfSnake. 4 replies.
Page 1 of 1 (5 items)
  • 06-02-2009 12:09 PM
    Link Room Sound issues
    So I have connected my Sky HD box to my BV7-40 via HDMI, I have also taken the Digital Coax from the Sky HD box to the SPDIF socket on the AV1 connector of the BV7,  but I get no sound in the Link rooms,  do you still need to use Scart,  I have changed the setting on the BV7 to use the sound from SPDIF and not HDMI
    Any Ideas, as I dont want to run a 10mtr scart lead to the TV
    Jon
  • 06-02-2009 1:38 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Link Room Sound issues
    The RF modulator is not able to distribute digital audio to link TVs. You will need an analogue signal. The same with picture.
    Stefan
  • 06-02-2009 2:10 PM In reply to
    but im not using a TV its a BEOLAB 3500 speaker only, so its just Audio  so I guess a scart lead or L/R phono cable
  • 06-02-2009 3:12 PM In reply to
    • stefan
    • Posts 1,733
    Yes. You only need a L/R cable connected to the SCART socket.
    Stefan
  • 06-02-2009 4:07 PM In reply to
    Jon, 'flipping' ridiculous I know.  Just a though, can you use AV4 as PC or some other miscellaneous setting and use L/R stereo for link rooms in addition to a digital signal for surround sound in your main room?
