Latest post 06-11-2009 11:37 AM by Peter. 3 replies.
Page 1 of 1 (4 items)
  • 06-10-2009 6:20 PM
    • B Price
    • Not Ranked
    • Joined on 07-11-2007
    • Virginia, USA
    • Posts 13
    Beogram 1800 cartridge
    Just bought a really nice 1800 / no cartridge. Everything seems to work well. I have a RX with mmc2 cart. and a 2400 with mmc 4000 cartridge. Dumb question? Will either of these cartridges fit the 1800 just for a test? Would like to hear the deck before spending $150. for a new cartridge. Thanks
    Filed under:
  • 06-11-2009 1:46 AM In reply to
    Re: Beogram 1800 cartridge
    The MMC2 will be fine.
  • 06-11-2009 11:02 AM In reply to
    • B Price
    • Not Ranked
    • Virginia, USA
    • Posts 13
    Peter, thanks for cart. info. on 1800, am trying to learn ~ these tables..............
    Filed under:
  • 06-11-2009 11:37 AM In reply to
    The only problem with this is that the pins in the MMC range can become loose so repeated removing and replacing is not a good idea. The last of the ones available seem to suffer from this in particular. It is clearly a design problem to do with having to wiggle the cartridges in and out as I have heard of some of the Soundsmith cartridges suffering the same problem. However in their case, Soundsmith offer a warranty on their new cartridges so are a better bet if looking for a replacement. The MMC20/MMCX000 range does not suffer nearly so much with this problem - the only fault I have seen a number of times on these is the stylus guard falling off.
