Latest post 05-23-2009 3:54 PM by yachadm. 2 replies.
Page 1 of 1 (3 items)
  • 05-03-2009 12:06 PM
    • dave1900
    • Not Ranked
    • Joined on 04-18-2007
    • gloucester
    • Posts 6
    The usual broken wiper problem on the BM 1900
    Hello everyone - what is the current state of play regarding the balance/bass/treble sliders on the 1900? Last time the sliders went wonky on my BM1900 I had to do that minute surgery of glueing all that parts back together, but alas the fault has returned and I don't fancy spending hours rebuiling the wiper/slider again.
    Has anyone found a replacement part yet?
    thanks
  • 05-03-2009 1:38 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: The usual broken wiper problem on the BM 1900
    I haven't found any good replacements for those potentiometers.
    My advice would be to give it another go, and use a better glue and/or clean better.
    I've repaired countless and never saw an already glued one back here.
    Clean everything, the brass parts should be rough'ened a bit using a glasshair brush or similar, and then
    superglue it back together, leave overnight and put back together.
    Use the real cyanoacrylate stuff, not the cheap tubes.
  • 05-23-2009 3:54 PM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Dave,
    Can you post a picture of this, with dimensions and Ohmic value?
    There is an old electronics shop here, which just put up for sale a whole bunch of NOS Ruwido slider pots.
    Let's see if there's a match here.
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
