Latest post 05-26-2009 4:20 AM by MartinM. 2 replies.
Page 1 of 1 (3 items)
  • 05-25-2009 5:23 AM
    • MartinM
    • Not Ranked
    • Joined on 08-07-2008
    • New Zealand
    • Posts 49
    Beomaster 5500 and 4 Ohm Speaker Compatability
    I have a Beomaster 5500 and am looking at upgrading the speakers. Issue is that the ones I am contemplating buying (Non B&O) are 4 Ohm impedance. Has anyone tried 4 Ohm speakers on a BM5500? Would I risk damaging the amp? Does the amp have a safety cut out? etc.
    Filed under:
  • 05-25-2009 5:27 AM In reply to
    Re: Beomaster 5500 and 4 Ohm Speaker Compatability
    They will work fine - the 5500 is used in MCL systems which will often result in difficult loads. Remember also that the 4 Ohm rating is just an estimate - all speakers have different values at different frequencies. Which speakers are you planning to use? The efficiency is probably more relevant anyway.
  • 05-26-2009 4:20 AM In reply to
    • MartinM
    • Not Ranked
    • New Zealand
    • Posts 49
    I am looking at a pair from Audio Pro. The Wigo 160
    25-200W; Sensitivity 90dB
    http://www.audiopro.com/templates/audio_pro_products/?id_products=486#
