1st March February 2012
Latest post 06-08-2009 12:46 PM by xegoon. 6 replies.
06-08-2009 9:18 AM
MikaelB
- Joined on 04-17-2007
- Herning, Denmark
- Posts 191
BeoVision 7-40 MK III, MK IV and MK V
I have a BeoVision 7-40 MK III and have just ordered a trade in to the BlueRay version.
The dealer then told me that the MK IV is the one without a BlueRay player, and it doesn't have 100/120Hz refresh rate, and the BlueRay version is called MK V and has a 100/120Hz refresh rate.
Is my dealer wrong, or is the current version of BeoVision 7-40 called MK V?
/MikaelB
Puncher
- Joined on 03-27-2007
- Nr. Durham, NE England.
- Posts 9,588
Re: BeoVision 7-40 MK III, MK IV and MK V
There is no MKV - the MKIV model has the Blueray and 100Hz panel.
MikaelB
- Herning, Denmark
- Posts 191
My dealer insisted that the first BeoVision 7-40 without DVD was not 100Hz.
He may have said that it was the first ones they delivered.
But you say that he is wrong, and all MK IV have 100Hz refresh rate.
/MikaelB
Bv7Mk3
- Joined on 12-01-2007
- Posts 272
Both the 7-40 MkIV non Blu-ray and the 7-40 MkIV with Blue ray is 100/120 refresh rate.Go to the Bang and Olufsen website and look on the specs.
Hope this helps!.
Bv7-55 & Bv7-32...Blue,lab1's x4,Yes4Blue, 6000x4Blue,Beocom6000 Blue,Beo5.Oh what a Blue set-up & a Beosound 5...After all,its Bang&Olufsen!
jk1002
- Joined on 04-16-2007
- Boston USA
- Posts 1,620
They still may sell off some MKIII sans DVD and those would not have the 100hz.
Cheers
JK
Russ
- Joined on 05-07-2007
- Washington, DC USA
- Posts 641
JK has it correct. The introduction of the non-DVD 7, and the really low price on it, was used to clear existing inventories of the 50/60hz panels. That has now been accomplished. Any BV-7 40 which you ORDER today will be produced with the 100/120 hz panel.
There is, as of yet, no such thing as a MK 5.
We kid because we love.
Bang & Olufsen Tysons Galleria
McLean, VA USA
xegoon
- Joined on 07-05-2007
- Posts 1,220
Current BV7-40" is MKIV version (100/120 Hz).
Anyway, you can even order a MKIII version (50/60Hz) with or without built-in BluRay, cheaper than the 100/120Hz version (about -25%, till the end of the stock)
Page 1 of 1 (7 items)
