Latest post 05-25-2009 9:26 AM by TWG. 2 replies.
Page 1 of 1 (3 items)
  • 05-25-2009 8:36 AM
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    Avant 32": Soap Opera Effect!?
    I've just bought an Avant 32" from my local dealer.
    I only knew the Avant from catalogs and when I saw it 2 weeks before it was love at the 1st sight :-)
    I had to buy it and now I'm enjoying the picture and soundquality. Wow!
    I had a MX4500 before that died so there was a very good opportunity. I'm impressed by the Avant. Does every B&O TV sound that good??
    But there's a little problem: The Avant shows some kind of "soap opera effect".
    Is there any adjustment I can  make to get rid of this or do I have to live with this effect?
    It's not very strong but I can see it sometimes during watching a DVD.
    Thanks!
  • 05-25-2009 8:48 AM In reply to
    • AdiS
    • Top 500 Contributor
    • Joined on 07-24-2007
    • Posts 196
    Re: Avant 32": Soap Opera Effect!?
    Hi there,
    I know what you mean. With our avant ( 32 DVD) we had the same problem - but there´s a possibility to solve: It´s a problem with the film mode.
    Follow this guide to deactivate: (all with the Beo4 remote)
    MENU --> SETUP --> 0 0 (sero sero) --> GO --> chose MONITOR --> PICTURE ADJUSTMENTS --> FILM MODE (<-- deactivate from AUTO or ACTIVATE)
     Be careful - don´t change the other things, only the Film Mode.
    Tell us, if the problem is solved!
    regards, Adrian
  • 05-25-2009 9:26 AM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    Hi Adrian,
    thanks for the tip but there's no option "Film Mode" in the service menu!?
    I did exactly what you said and there are just many options in "Picture Adjustmens" with cryptical letters (shortcuts!?) and numbers (values!?) in this menu.
    Any other tip?
