Latest post 05-18-2009 1:32 AM by PhilLondon. 4 replies.
Page 1 of 1 (5 items)
  • 05-17-2009 5:05 PM
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    beoport without an audio master
    Can beoport be connected to a computer and a couple of lab 4000s and be controlled by the beo4? or does it require
    an audio master. . .
    i.e. in my study can i use my beoport and remote without it being masterlinked in?
    MJM
    I'm ready for something new that I actually want to buy!
  • 05-17-2009 5:15 PM In reply to
    Re: beoport without an audio master
    In the same room you can connect an eye to it and control it with a Beo 4. You cannot, however, run ML to another zone and distribute the N.MUSIC & N.RADIO to that room.
    There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
  • 05-18-2009 12:20 AM In reply to
    TripEnglish:
    I thought you could set the Beoport as audio master... (on a PC)
  • 05-18-2009 12:41 AM In reply to
    Yes, you can use BeoPort without any audio master, I've been doing that for 4 years.
    If you have no other B&O master (= video master, for instance), you simply set the BeoPort to option 2, plug the infra-red eye in the box & use your Beo4 for NMUSIC, NRADIO and CD.
    You can link the BeoPort to another room, I've had a BeoLab 2000 working like that for almost a year.
    The only limitation, when having no audio master, is that if you add a video master (BeoVision) and integrate all with Masterlink, you could control the video sources from your PC/Beo4 via IR eye , but no longer control the BeoPort from your TV, as option 6 on BeoPort with no audio master makes the TV "blind".
    Reunion Island is greeting you!
  • 05-18-2009 1:32 AM In reply to
    Chrisreunion:
    In that case the TV should be in option 2, the Beoport in option 0. All speakers connected to the TV and no IR eye on the Beoport. That is if they both in the same room.
