For
an unknown reason the tuning of the TV stopped working.
At the beginning the tuning went off slightly and corrected itself, than the issue got worse and worse, you had
reception, than you did not.
Now its so bad that when you run an auto
or manual tuning no TV stations are recognized.
I have a VCR attached
which I tuned at the same time about 7 months ago and the reception of
the programs is still OK - so all I can do is flip channels through on
the VCR instead of using the TV.
Would appreciate any ideas you may have.
