1st March February 2012
Latest post 05-18-2009 5:14 AM by Jandyt. 19 replies.
05-04-2009 5:14 PM
BeoMeowth
- Joined on 01-31-2009
- Posts 16
Can't seem to find much informaion on Beosound 2300, is this same as Beocenter 2300?
I have the Beosound 2300 and I wish to find out more information about this unit. However, I can't seem to find much information on the Beosound 2300. Was this like an odd ball or something?
For example, I can find info on the BeoCenter 2300 on this site, but there's no listing under BeoSound 2300? Weird?
PhilLondon
- Joined on 04-16-2007
- London
- Posts 2,545
Re: Can't seem to find much informaion on Beosound 2300, is this same as Beocenter 2300?
Beosound 2300 was just an amplifier. If what you have is the CD/Radio player with the glass doors, then you have a BeoCENTER 2300 (or a Beosystem2300, if sold with Beolab 2500).
birgerbum
- Joined on 03-15-2009
- Posts 230
HI
go to mainsite beoworld choose products musicsystems beosound systems choose beosound 3000 in the bottom there is a link to beosound 2300
regards
jan
birgerbum
- Posts 230
hi
I have been doing a little investigation it seems there are some confusion about this it's listed as both becenter 2300 beosound 2300 and beostystem 2300/2300 with active beolab 2500 they are all the same
regards
jan
BeoMeowth
- Posts 16
Thanks for the instruction birgerbum, but that linke is to the BeoCenter 2300.
Here's something that I foudn on ebay.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&Item=140318095492&Category=3276
On the back of my machine it actually has that sticker that says beosound 2300, and yes it has a sliding door and a CD player. What the freak is this thing?
BeoMeowth
- Posts 16
so according to this site beocenter 2300 = beosound 2300? Is it like called beosounds 2300 in the US and called beocenter 2300 in europe or something?
or is this some knock off, and i'll find out it that the Bang & Olufsen logo actually says "Bing @ Olufson"... ha h aha
XavierItzmann
- Joined on 01-24-2009
- Posts 226
Well, I own a BeoSound 2300 which I bought in 1998... So I must own the equivalent of an unicorn!
BeoMeowth
- Posts 16
i also own a beosound 2300, but, i don't know what's the specs on it... weird
Dave
- Joined on 04-17-2007
- Brisbane, Australia
- Posts 2,328
interesting! Must have briefly been called beosound before it was updated as beosound 3000
beocool
- Joined on 10-17-2007
- the Netherlands
- Posts 5,514
I think it was called Beocenter 2300 when it was first introduced or Beosystem 2300 when it was bought together with Beolab 2500's. After a while it was renamed Beosound 2300. As far as I know at the same time the two way communication was dropped. Not sure though...
BeoMeowth
- Posts 16
but the thing is that it is labled beosounds 2300, not beocenter or beosystem =| time to write to B&O about this madness!?
The_Beonic_Man
- Joined on 12-22-2008
- Bath, UK
- Posts 479
I also owned the BeoSound 2300 in the 90s and it was definitely called the BeoSound 2300 not a BeoCentre or a BeoSystem. It had CD and radio with the red digital display, the glass sliding doors and the small CD clamper. I bought it from Kingston upon Thames dealership then traded it in several years later at another. I am quite certain they did change the name to a BeoSystem at a later date and that was because of speaker options.
Simon.
Peter
- Joined on 02-12-2007
- Posts 9,572
They started off as Beocenter 2300 which was called the beosystem 2300 when Beolab 2500s were attached. When the Ouverture replaced the 2500, the 2300 was renamed Beosound. About 1994.
Not to be confused with the Beomaster 2300!!
BeoMeowth
- Posts 16
so the BeoSound 2300 is just a BeoCenter 2300 with a different sticker on the back?
Peter
- Posts 9,572
Yes. There were changes made through its production run though. The CD mechanism changed at least once for instance and it lost the two way remote facility fairly early on. But is essence, they are the same.
Peter
- Posts 9,572
The Beosystem 7000 (for instance) used a remote called the Beolink 7000. This sent out commands like the normal Beo4 but also had a receiver so could accept messages from the music system, if said syatem was fitted with a transmitter. This had the huge advantage that one could control a system from another room and retain full control of what it was doing and its status. for instance one could monitor recording levels on the tape player, see which track was playing on the CD and get RDS information about the radio channel. It also allowed programming of the system in a very complax way - one could set programmes to play on different days and times for years ahead. An incredible remote for its time! The first 2300s would work with this remote and the simpler Beolink 5000.
BeoMeowth
- Posts 16
Problem solved once and for all, from B&O:
Dear Chang,
The product you have is the US version of the BeoCenter 2300, and was actually named BeoSound 2300. We have attached the user guide, and please let us know if you need further information.
Kind regards
Bang & Olufsen
a/s
Mette Krabbe Helmholt
BeoCare
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Peter :for instance one could monitor recording levels on the tape player,
Peter, You have mentioned this a couple of times in the past, but I have yet to see it! When about to record, one can see all the red LED (recording level) bars on the Beocord 7000. Am I supposed to see them replicated on the Beolink 7000 too? Have I misunderstood something? Andy T.
Page 1 of 1 (20 items)
