Latest post 05-10-2009 7:48 AM by Keith Saunders. 5 replies.
Page 1 of 1 (6 items)
  • 05-10-2009 6:11 AM
    Puc Codes
    Hi everyone does anybody have the upto date puc code list for STB i have a Samsung BD-P1600 Player and what to control through my Beo5
    thank's
  • 05-10-2009 6:14 AM In reply to
    Re: Puc Codes
    In the "GROUP" section HERE you will find a complete list of products available in the PUC library.
    Regards Keith....
  • 05-10-2009 6:22 AM In reply to
    Re: Puc Codes
    Many thanks Keith
  • 05-10-2009 6:37 AM In reply to
    Re: Puc Codes
    Hi Keith will they be adding more puc codes in the near future as my Samsung BD-P1600 is not currently on the puc code list
  • 05-10-2009 7:44 AM In reply to
    • Michael
    • Top 200 Contributor
    • Joined on 05-24-2007
    • Atlanta, USA
    • Posts 318
    Re: Puc Codes
    If you havn't already, then try the other Samsung BluRay Puc codes.  I know Samsung is pretty good about not changing the codes too often.  My BD-1500 works fine with the older codes.  In the US there is a Puc Code entitled simply Samsung BluRay due to this fact.
    Sony on the other hand is a completely different story.
    I'd give the BD-P1200 a shot.
    -Michael
  • 05-10-2009 7:48 AM In reply to
    Re: Puc Codes
    B&O provide dealers with PUC updates on a regular basis, however ultimately B&O Denmark decides if a unit is to be added to the PUC library or not.
    Clearly, if the unit is popular, or they get a lot of requests, then the STB is added in time. I also understand, for a less popular model which a dealer needs adding, they can pay to have it added, but I am sure not many take up this option.
    Whilst you Samsung BD-P1600 is not currently in the PUC library, as you have a Beo5, then it can be controlled directly (i.e. not via the PUC) An XML file would need to be produced for you Samsung unit and the unit would need to be visible to the Beo5.
    I also agree with Michaels point as Samsung use NEC protocol for almost all their units
    Regards Keith....
