Latest post 04-30-2009 5:42 AM by rayfenwick. 3 replies.
Page 1 of 1 (4 items)
  • 04-26-2009 11:42 PM
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    What Recession?...
    Goodness knows what this Beogram 7000 would have sold for if it included a cartridge.
  • 04-27-2009 3:10 AM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: What Recession?...
    Welcome to the magical, mystical world of BeoGram 7000 valuation! Laughing
    A good deck, but worth what they fetch? No way...  Get a Beogram 4000 if you want engineering excellence.
    If anyone is wondering what the allure is for the 7000 - it's purely the fact it was the last and therefore newest Tangential deck made by B&O, and it also has an inbuilt pre-amp - which means it can be plugged straight into the AUX socket of any modern B&O system and will work straight away. Bear in mind you will have no remote control of it though!
    Lee
  • 04-27-2009 4:18 AM In reply to
    9 LEE:
    Lee
    Not much magical or mystical - it's all down to condition. If the deck is actually like new as described, then the demand would push the price up here as well. In my opinion, £1000 is not out of the question!
    I take your point about the BG4000 but at least the BG7000 is likely to work. Most 4000's don't, unless you have the ability to fix them or know a man that can!
    The BG7000 does implement datalink so the question of remote control depends on what you connect it to. BS9000 is a no but all the Ouverture series are a yes.
    Regards Graham
  • 04-30-2009 5:42 AM In reply to
    joeyboygolf:
    Presumably the lack of datalink on the AUX of the BS9000 must have saved B&O an extra, ooh, 25p in components on a £3000 stereo.
    I expect that of lesser brands (and lesser prices), but if I owned an Overture, and decided to upgrade to a BS9000, I'd be cheesed off that the remote control of the turntable stopped working.....
    Ray
    Я люблю Банг и Oлуфсен
