Latest post 04-30-2009 12:45 AM by ProGram. 3 replies.
Page 1 of 1 (4 items)
  • 04-29-2009 6:41 PM
    • Clifford
    • Not Ranked
    • Joined on 04-29-2009
    • Hudson, Pa
    • Posts 7
    Mute on the Becocenter 9500
    I have the Beocenter 9500 and it has extremely low volume. Any Ideas on what it may be?
  • 04-29-2009 6:56 PM In reply to
    Re: Mute on the Becocenter 9500
    Hi Clifford
    Try to change the mute relai .Is it the problem no matter what source you use(radio cd tape?)
    regards
    jan
  • 04-29-2009 7:58 PM In reply to
    • Clifford
    • Not Ranked
    • Hudson, Pa
    • Posts 7
    Yes it is the same no matter the source. Tape CD Radio, they all work but with very low volume even on max. Same with the Headphones Low vol even on max...
  • 04-30-2009 12:45 AM In reply to
    • ProGram
    • Top 500 Contributor
    • Joined on 06-01-2007
    • NRW, Germany
    • Posts 145
    Try the the speaker 2 - sockets, they have no relay. When it's still low, there will be a different problem.
