Stan,
Yes you can, BUT not with the Beo5 Configuration Tool.
In the earlier versions of the Beo5 Configuration Tool it would let you change the number screen IR assignments, but in the most recent version this facility was removed.
However, these assignments can still be done in a created XML file.
