Latest post 04-17-2009 1:22 PM by mauszwerg. 7 replies.
Page 1 of 1 (8 items)
  • 04-13-2009 10:14 AM
    Wallbracket MX range
    Hello everybody and Happy Easter
    Could anyone please tell me wether the motorised wallbracket with serial number 0019563 fits the MX 4000. If not, can it be modified?
    Thank you Ralf
  • 04-13-2009 12:46 PM In reply to
    Re: Wallbracket MX range
    If the plug has 5 pins it will work with MX4200.
    If the plug has 4 pins it will work with MX3500,4000,4002
    Regards Graham
  • 04-14-2009 2:45 PM In reply to
    Thank You
    ralf
  • 04-16-2009 2:24 PM In reply to
    Hello
    today I received my new wallbracket it has the right 4 pin plug, but it seems too big for my MX 4000. Maybe it is for a MX 6000. Could anybody please send me the measures of a MX4000 wallbracket. Does anybody have a spare mounting plate for a MX 4000?
    Thanks Ralf
  • 04-16-2009 4:11 PM In reply to
    AFAIK B&O did not make a wall bracket for 28in TV's, only the 21in MX4000 series. However, someone may have interchanged the mounting plate for another type.
    The mounting plate should look like this one here
    http://i602.photobucket.com/albums/tt104/TDL-STUDIO/000_0215.jpg
    Regards Graham
  • 04-17-2009 12:56 PM In reply to
    I heard that there were brackets for the MX 6000, but only for dealers to present the TV in a shop. I bought the bracket from a former dealer and he said that it was for MX and LX TV´s. I did not ask if it fits the MX 4000. This picture shows it with my MX 6000.
  • 04-17-2009 1:03 PM In reply to
    That looks and sounds like a special for display purposes. How do you fix it to the wall so that it can take the weight of a 6000 TV????Hmm
    They were never released for general use as far as I know. The health and safety implications would have killed the product off.
    Regards Graham
  • 04-17-2009 1:22 PM In reply to
    That´s what i thought. Fixing it to the wall should be no problem, as our walls are made of concrete or massiv bricks. I will keep this one for the future and search for another one for the MX 4000.
    Thank You
    Ralf
