Latest post 04-20-2009 12:36 PM by birgerbum. 2 replies.
Page 1 of 1 (3 items)
  • 04-20-2009 10:11 AM
    BeoSound 9000 CD Deck Problem
    Hi I have a BeoSound 9000 (over 5 years old)  and the CD deck has a problem. When the button on the remote is pressed the light comes on sometimes but not always. It just stays stuck on CD position 6 which doesn't play or move to any other CD positions. Any suggestions will be appreciated.
    Richard
  • 04-20-2009 10:26 AM In reply to
    • Stan
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 593
    • Gold Member
    Re: BeoSound 9000 CD Deck Problem
    The first step to troubleshooting almost any BS9000 weird behavior is to clean any dust from the hand sensors - these are 2 small clear posts that stick out near the top of the metal deck (the metal surrounding the CD holes) to the left and right of the cd 1 and cd 6 holes.  When clean, these sense obstructions to the CD carriage path so that it doesn't wack your hand at high speeds.  When dirty, they can cause all kinds of weird things to happen.
    If this doesn't work, then there's always the hard reset (unplug for ~ 1 minute).
    After that, it usually requires a professional...  or the help of professionals on this board (not me).
    Stan
  • 04-20-2009 12:36 PM In reply to
    HI
    Have you tried to change your batteries for the remote
    regards
    jan
