Latest post 08-13-2009 12:03 PM by Peter. 1 replies.
Page 1 of 1 (2 items)
  • 08-12-2009 7:31 PM
    • fabien
    • Not Ranked
    • Joined on 08-12-2009
    • Posts 1
    BC2 and projector
    Hello,
    I have a BeoCenter 2 and would like to connect it to a high resolution digital projector (probably Epson EMP-TW700 - 1280 x 720 pixels). Do you have any recommendation how I should do that to retain the best quality?
    Fabien
    Filed under: ,
  • 08-13-2009 12:03 PM In reply to
    Re: BC2 and projector
    Use Scart output - it is RGB and the best you can get from the BC2.
