Hi all,
I some problems with the picture quality on my two linked Beovisions. When looking on a dvd or v-mem recording sent from the master tv (BV5) to any of the link tv:s (BV7 Mk1 as first link tv and BV6 mk 1 as second link tv) the pq is quite ok. Not excellent but ok. However, when watching an ordinary tv programme on any of the link tv:s the pq is really bad. Even worse if both tv:s should be on at the same time.
I've done some searching on the forum and come to understand the importance of high quality RF cable etc. but what beats me is why the dvd and v-mem signals from the master tv gives an ok pq while the same cannot be said about the ordinary tv channels? Picture is fine on the master tv so it can't be the analogue tv-signal itself.
I have tried to change the link tv frequency of the master tv without any visible improvement on the link tv:s. I did however notice that when I tried to change the link tv frequency of the link tv:s in accordance with the user guides of the BV 6 & 7 (never really able to though since I came direct to the fine tune menu. It seems as the tv:s autodetect the new frequency) it seemed as if I could make use of the analogue receiver of the master tv and have the picture sent to the link tv:s with better result. Problem with this solution is that
1. I can only watch the same programme at the same time on the tv:s, thereby excluding the rest of the family who does not always have the same preferences as me,
2. Stored memory pages on text tv are no longer available on the link tv:s, and
3. I have to do the same operation again if the tv is shut off. The link tv:s doesn't store anything.
Any input on what I am doing wrong would be highly appreciated. I have no RF amplifier installed but since the pq is ok when sending dvd and v-mem signals as well as when I'm trying to adjust the frequency of the link tv:s I am not really sure that it is the strength of the signal sent from the master tv (or from the BV7 to the BV6) that should be blaimed.
Regards,
Emil
