Latest post 11-24-2007 5:32 PM by 9 LEE. 1 replies.
Page 1 of 1 (2 items)
  • 11-24-2007 12:25 PM
    Wall mount Beovision 7-40
    Regarding fix wall mount Beovsion 7-40 with the STB brackets, has anyone put their Beolab 7-2 above the Beovision 7-40 ?
    If I put the Beolab 7-2 below the TV, the viewing angle is too high. Any suggestions will be highly appreciated.
  • 11-24-2007 5:32 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: Wall mount Beovision 7-40
    Above?!
    Gosh - that's a new concept!  Not quite sure what i think of that to be honest.  Are you mounting it above a fireplace then?  David Lewis would probably pour his coffee down your front and put his danish pastry in your top pocket for even suggesting such a thing!
    LaughingLaughing
    Lee
