Thanks for that Andy - no I hadn't found it - however, I want info on the other end ie the din plug, I have the eye wired with a 5 core cable and a cut end where it 'd plug into the ml/mcl, passive etc
Thought one of the techies might have helped!
Bonne weekend - misty here in Nth Worcs!
Tony
									    I always try to operate using/following the KISS principle --  Keep it simple stupid!
