1st March February 2012
Latest post 07-02-2007 8:02 AM by Kevin. 21 replies.
06-28-2007 6:34 AM
Keith Saunders
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
I was reading Lintronic newsletter this morning and noted the following statement:- LINTRONIC IS BEO5 READY Yes sir, we ready indeed. Bring it on TT455-RT-238 will support the new upcoming BEO5, allowing you to control by IR or RS232, or power line carrier signals: Amplifiers, tv/screens, CD/DVD players/recorders, projectors, relays, light systems, X10, computers, HomeAutomation programs etc. etc. So, we must assume that they have had a evaluation Beo5 made available to them for test
ChrDH
- Denmark
- Posts 493
Re: Lintronic ready for Beo5
I thought that the Beo5 could be programmed to control non-B&O equipment, making a Lintronic-solution redundant. But am I missing something out here? best regards Christian
Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
Keith Saunders
- Posts 3,810
Christian, I thought the same as you, hence why I raised the subject.
Daniel
- Joined on 04-17-2007
- Svinarp, Sweden
- Posts 1,284
Lintronic can controll hidden devices. Beo5 not. Lintronic can be programmed to make several commands from one incoming signal (instant or one by one). Don´t know if Beo5 can do this.
ChrDH
- Denmark
- Posts 493
Hi Daniel (tak for sidst :) ), what do you mean by hidden devices? Visually hidden or?? best regards Chr.
beo-ap
- Posts 231
I have no idea what Lintronic's relationship with B&O is, so they may know something about Beo5 that we don't. However, as a Lintronic user, it does more than just convert IR codes. In fact it does much more. It can receive external triggers from relays, x-10, etc. and convert them to IR. It can execute macros, and do other IR-related complex tasks as well. Even with Beo5, I will still use Lintronic.
Daniel
- Svinarp, Sweden
- Posts 1,284
ChrDH:
Tack själv, nr 1! Yes, in a drawer or something. I will place my DVB-T in a closet the other side of the wall were the TV stands. With a LX I need Lintronic to do this.. /Nr 2
mr_anders_son
- Joined on 03-27-2007
- sweden
- Posts 1,032
Daniel:Lintronic can controll hidden devices. Beo5 not. Lintronic can be programmed to make several commands from one incoming signal (instant or one by one). Don´t know if Beo5 can do this.
It will do macro command = one hit several commands ;-)
Daniel
- Svinarp, Sweden
- Posts 1,284
....mr anders(son): It will do macro command = one hit several commands ;-)
It = Beo5 ?
Alex
- Bath & Cardiff, UK
- Posts 2,990
....mr anders(son):It will do macro command = one hit several commands ;-)
I can see this could easily become an absolute headache
Weekly top artists:
The Stig - ver. 1.7
- Joined on 06-20-2007
- Posts 898
yes the beo5 can be used with lintronic because it use all the same commands as beo4... forget about the control of non B&O products it's not gonna happen, only in beoliving for light control and sots things. stb and dvd is to be controlled by the puc controller (the change stb-controller)
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
bang1: forget about the control of non B&O products it's not gonna happen
Hi Bang1. Can you tell us what makes you think this? This seems to conflict with what B&O told us in Struer.
Andy T.
The Stig - ver. 1.7
- Posts 898
Hi Andy if you look at the history b&o don't make a diverse, that takes away sale from there own product. f.ex if the beo5 controllers a 100£ hdd rec. what effect cut that have on the 1000£ hdr2? and so on, you see when DVD2 comes the DVD controller don't get update as frequently anymore, only when a costumer pays 300£ for it
Alex
- Posts 2,990
No the Beo5 is a learning remote, we've known that for quite some time. I guess the idea is that while the BeoSystem 3 is very flexible, you can't really run IR Blasters all around the house, and hance a remote control which can control other things would help. There are so many things which now use IR codes to work, such as A/C units and even velux offer an IR controlled opening/closing solution I believe. A learning remote is the perfect solution to being able to control these kinds of things...
Weekly top artists:
The Stig - ver. 1.7
- Posts 898
Yes that right, for light control a/c and so on, not for DVD, STB or pioneer plasma display (exampel)....
Jandyt
- Posts 13,004
This is probably why we can't update the Beo5 ourselves, it has to be done by a B&O dealer. In the Beoliving room in Struer there is a Samsung projector, bit useless if Beo5 can't work it!
The Stig - ver. 1.7
- Posts 898
The samsung projector is controlled by the puc controller in BV7 and BS3, not with Beo4 or 5.
Jandyt
- Posts 13,004
Sorry A fool is a wise man until he opens his mouth!
Andy T.
Michael Lindgaard
- Joined on 06-22-2007
- Posts 15
Yes, we are BEO5 ready and our TT455-RT-238 is much more versatile then first anticipated. BEO5 will be a nice add-on ... and vice versa ... not a mutual competitor  TT455-RT-238 can receive triggers from: - B&O Keyring, BL1000, BEO4, BEO5 - Bose Lifestyle system - All NEC code based remote controls (Apple, for example) - Relays, switches, contacts, PIR motion detectors, telephone relays, etc. etc. - All types of X10 transmitters: Handheld, wall mounted, RF/IR, dusk/dawn sensors, etc. We control ... welll, se our Triggers and Actions page .. you will be amazed. And these are just examples. Furthermore, the TT455-RT-238 is a nice PC gateway allowing you to control audio/video devices ... also your B&O system ... via SMS, email, HomeAutomation, etc. TT455-RT-238 is often used as man-machine-interface (MMI) controlling for example, projector On, input selection, light levels, curtains, down, lock door :o) Up to 32 actions in ONE macro. Using an industrial 2-wire long range RS485 network, up to 32 pcs. TT455-RT-238 may communicate around the house. We are currently about to support PowerMax security system, allowing you to arm/disarm the house from your bedsite or control the lights all over the house or the curtains, etc. with the BEO4. You can have different reactions in different rooms to the same trigger. Example: When it gets dark, close curtains in one room, turn on lights in fish tank in another room, etc. When hitting AMEM button, turn off stereo in all the kids rooms, close the garage door, set outside light level to 5%, etc. Controlling curtains by relays instead of IR is betting bigger and bigger. I could go on and on ... but why not drop by and see for yourself. Regards, LinTronic, Michael Lindgaard
Kevin
- Joined on 02-15-2007
- Moderator
- Posts 1,256
As Michael´s very full description says a superbly specified system which should complement any B&O system Beo5 or 4 and one we hope to handle ourselves in the near future. A quick thanks to Michael too who has now put a link to Beoworld from his main website, details of which you will find on our links page.
Page 1 of 1 (22 items)
