1st March February 2012
Latest post 03-20-2009 2:19 PM by Michael. 15 replies.
03-18-2009 8:37 AM
Hiort
- Joined on 04-17-2007
- Posts 383
Beovision 8 & STB problem
I have a new BV8 32" with a STB connected.
(I have the DVB-T module installed but not used)
The B&O installer installed the STB as V-AUX on one of the scart connections.
To start viewing I need first to touch "TV" at the Beo4 to start the BV8 and then "list" & "V-AUX" to start also the STB.
The problem is that sometimes I cannot get the sound out (picture goes on fine). I have then to do the procedure once again (sometimes more times) and then it "suddenly" works as it should...
Preferably I would like to touch only one button to start "everything", but at least the sound should go on correctly if I do the first mentioned sequence.
Any suggestions?
/Claes
_____________
Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
1:st prize winner Beoworld January Price Draw.
Karel Uyttendaele
- Joined on 05-19-2007
- Aalst, Belgium
- Posts 682
Re: Beovision 8 & STB problem
Strange... I would have configured it another way.
If only the STB is connected then I would connect it to AV1 -> STB (DTV)
That way you can start your STB by simply pressing the DTV button on your Beo4...
The race for quality has no finish line- so technically, it's more like a death march.
Hiort
- Posts 383
Agree, after reading the manual. The installer guy did the works so I was not really involved.
If i touch "DTV" with the current configuration, the internal DVB-T module starts....
Maybe that module makes it impossible to assign e.g. AV-1 to STB (DTV).
I will make another try tonight.
_____________
jk1002
- Joined on 04-16-2007
- Boston USA
- Posts 1,620
There is DTV and there is also TV? What do you have TV used for? I am using TV for my Apple TV and DTV for my Wii and then DVD for my BC2.
Works like a charm. I dont have the DVB module but don't think that prevents you from using TV if DTV is linked to it.
Hiort
- Posts 383
jk1002:
When I press "TV" the set is just starting up, probably using the antenna inlet (no antenna connected. Only STB).
How can I make the configuration so that I press "TV" and get the "AV1" activated (and the STB)?
_____________
Keith Saunders
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
If you have a DVB-T module installed in any Beovision it is assigned to DTV automatically and cannot be changed.
It also means that if you have the DVB-T module installed you can only control ONE STB
Hiort
- Posts 383
Keith Saunders:
Thanks Keith, thats what I thought regarding DTV button.
What´s your call regarding the TV / V-AUX setup I have?
If I press "List" / "V-AUX" / "GO" everything starts up nicely, but then I get no sound
_____________
Keith Saunders
- Posts 3,810
If you do NOT use the TV button and press "List the V.AUX then GO, when you get picture but no sound
Press MUTE twice.
Does the sound come on ?
Hiort
- Posts 383
Yes, the sound comes on if I press MUTE twice. Thanks for the tip!
Solves part of the problem, but I don´t really see the logic to why it works that way.
(B&O tells med that TV button is dedicated to the analog aerial in)
/Claes
_____________
Keith Saunders
- Posts 3,810
Claes,
Whilst using the "mute" key is a workaround, it is not a solution.
The problem you have identified is caused by a software problem and can only be fixed with a "yet to be produced" software update.
You should contact your dealer and get them to report it to B&O who may already be aware of this issue.
Hiort
- Posts 383
Keith Saunders:
Claes,
Thanks Keith,
I will let my dealer know.
Also, my dealer tells me that they have put a request in to denmark to let the TV button to be freely assigned to any input. May also come in that software update
/Claes
_____________
Keith Saunders
- Posts 3,810
Hiort: Also, my dealer tells me that they have put a request in to denmark to let the TV button to be freely assigned to any input. May also come in that software update
Claes,
That will NOT be possible until they stop using analogue tuners
Michael
- Joined on 05-23-2007
- Atlanta, USA
- Posts 318
Keith Saunders: Hiort: Also, my dealer tells me that they have put a request in to denmark to let the TV button to be freely assigned to any input. May also come in that software update
Claes,
Keith,Does this mean that it will not be possible to update that aspect of the software until there is physically no analog tuner in the box? Or is it until it's no longer being mandated to include an analog tuner ( as is occuring in the US).
I believe with the BS3 ( US version) you can disable (in the service menu) the 2nd tuner module which is hardwired to the DTV input. Is this not possible with the BV8 in Europe?
I hear your pain Claes. I would give anything to have my "Over The Air" HDTV (the ATSC module hardwired to DTV in the US) be assigned to simply "TV". I feel ridiculous every time I have to explain to a guest that they need to ignore the "TV" button when they want to simply watch TV.
Hiort
- Posts 383
Agree Michael,
That was pretty difficult to explain to my wife as well....
/Claes
_____________
jk1002
- Boston USA
- Posts 1,620
@ michael: Our BV8 in the US doesnt have the analog tuner. So we can use it actually freely. I have mine setup to work with my Apple TV.
Cheers
JK
Michael
- Atlanta, USA
- Posts 318
Thanks JK.
I was actually thinking of the ATSC module in the BS3 that is hardwired to the DTV input. My hope was that it's ability to be disabled in the service menu might be relevant in Claes' situation. It sounds like it probably is not and as you pointed out the US/EU versions appear to be very different animals.
Page 1 of 1 (16 items)
